Company Logo Shop Now
Order Ford 5000 Parts Online
Just Bought A 5000 Row-Crop Gas
KCTractors
04-29-2020 18:58:03
I am trying to find out how to decipher the numbers on the bell-housing. The numbers are top C2044C
middle 5D30B
bottom C465941
Number on the lower block is E709922 I take it as a 356 engine. The fellow I bought it from tell me it is a 1975. Thanks Guys
Sean in PA
04-30-2020 12:38:15
 Re: Just Bought A 5000 Row-Crop Gas in reply to KCTractors, 04-29-2020 18:58:03
Yes, that makes sense. 5000 row crop (also called a 5200) with gas engine, independent 540 rpm PTO and 8 speed transmission.
KCTractors
04-30-2020 11:16:44
I still had the number wrong, it is E2024C. Does that make sense?
Sean in PA
04-30-2020 06:12:10
E2044C makes more sense, but not completely. The first 4 indicates that the transmission with that model number stamped into it was in a tractor that had a diesel engine with horizontal exhaust when it left the factory. If it truly has a gas engine now, then as I said before, either the engine or transmission has been swapped out at some point over the years.
KCTractors
04-30-2020 06:06:59
I typed in the wrong letter in the top number. It is E2044C. That would mean that I have 5000,256 gas engine, 8 speed transmission, Independent pto made in 1975.
Am I right!
Sean in PA
04-30-2020 04:19:37
C2044C would be a 3000 series row crop chassis with a diesel engine with horizontal exhaust, independent 540 rpm PTO and an 8 speed transmission.
5D30B - April 30 1975 day shift
C465941 - 1975 serial number
E709922 is the engine serial number from a 5000 series engine, which should have a 256 ci engine, not 356.
A couple of problems:
1. They never made a 3000 series row crop as far as I am aware. In the title of this thread you said "5000 row crop". A 1975 5000 row crop model number would start with E instead of C.
2. The fourth character inth emodel number you posted, 4, would mean that it has a diesel engine with a horizontal exhaust but you say it has a gas engine. I'm also not sure if they use the 4 designation prior to the x600 series, but since it was made in 1975, it was made durign the oerlap between the thousand and x600 series so it might have been.
So my guess is that either the transmission or the ngine was replaced at some point, or you got the model number wrong. A 1975 5000 row crop with a gas engine, independent PTO and an 8 speed trans would be E2024C.
Ultradog MN
04-30-2020 02:09:51
Something haywire with your model number - C2044C
C makes it a 3000.
A 5000 would be an E there
20 = row crop
The first number after the 20 should be fuel type. 1 for diesel, 2 for gas, 3 for LP.
There was no #4
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
