Ford 960 Oil Leak
Retcol
I have a Ford 960 that is leaking some oil around the plate where the oil filter mounts. is there any way to stop this or is there a sealant I could use that withstands heat?
I take it you have a spin on filter conversion? If it's a 960, and not a 961, it had a cannister type filter from the factory. If it has been converted there will be an o-ring or gasket between the engine block and the conversion plate.
"I have the spin on filter. How can that O ring be replaced?"
On mine, you take the oil filter off and there is a nut that lets you
remove the adapter plate. The seal is between the plate and the block.
