Tx Jim
- Location
- Coyote Flats, Texas
I had local mechanic remove the inj pump on my 6700 to have IP repaired because it was leaking fuel externally plus around IP driveshaft into engine crankcase. Mechanic that removed IP took ill so I asked my truck mechanic to install repaired IP with my supervision. We got IP installed & air bleed out of system & engine running but I'm not sure we have IP timed correctly. My tractor has had a crate engine installed with a Lucas model 8523A800Y emissions IP. Engine starts fine but I think it sounds a little different BUT that could be my imagination. Also there's a plastic fuel return line that's leaking & my mechanic thinks a feral is missing. This fuel system has a hand pump that's leaking that I can't locate in NH parts because fuel system is for crate engine. I've looked at newer model similar size NH tractor parts schematics for feral & hand pump with no success. NH tech manual I have little to no help.
Thanks for any help,Jim
