Company Logo Shop Now
Order Ford 3000 Parts Online
72 3000 gauge cluster not working
new old SU tractor
04-28-2020 08:16:23
My dash gauges don't work and I'm wondering is there a aftermarket tach and gauges for my 1972 3000 diesel? I can't stand nor do I trust idiot lights, as when they come on I feel damage is already occurring.[color=blue:d008e766c4][/color:d008e766c4]
Ultradog MN
04-29-2020 02:22:49
 Re: 72 3000 gauge cluster not working in reply to new old SU tractor, 04-28-2020 08:16:23
That red light on the dash is much more apt to get my attention than a guage - especially after a couple of hours in the seat.
Aftermarket clusters are available from this site. If yours is original there's about a 98% chance the tach and hour meter are kaput anyway. They were notorious for early failure.
If you are even remotely thinking about an alternator upgrade to your tractor someday you might consider switching over to the 3600 style cluster and tach drive. 3600 tach is not driven off the generator. It is driven off the oil pump drive gear below the oil filter.
There is quite a bit of info about doing the switch if you do some digging in the archives here.
Destroked 450
04-28-2020 11:10:04
There are aftermarket dash cluster available for your tractor but you should first check to see if yours are bad.
There's a fuse in the harness behind the cluster that could be blown, the voltage stabilizer on the back of the cluster could be bad, temp, fuel sending units could be bad
Has for the idiot lights that's for the charging system and oil pressure, there is not factory or aftermarket gauge clusters that replace these lights with gauges.
Jim L WA
04-28-2020 09:22:01
Did you check for new gauges on this site? Click on "Tractor Parts" toward the top of the column at the left.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
