1974 ford 3000 Remote hydraulics
yamblaster99
New User
So I had a ford 771 front loader, and I just brought double acting lift cylinders for it, (it has single). The left side is my tilt cylinders which are double acting, and the right side is where my lift cylinders. Is there a possibility that I can somehow make the right side able to do double acting instead of single? Do i change out the detents? If so where would i find that part? I dont know what model number this remote hydraulics are either so i dont know where to find parts for it. Here is a picture if that can help
[/img]
If you can, get us a photo of the front
of your valve.
I think there is a slotted screw there
that you turn in (or out?) to switch from
single acting to double acting.
Yes.
The hex one.
As Fordfarmer says, be careful with it.
Do not force it.
Use penetrating oil, heat, whatever if it
won't turn fairly easily.
Okay, thats really cool... Would've never thought of that. I also have another question, if i want those double acting cylinders to float would i turn it back? (like for plowing snow) or do I need a Certain solenoid valve like the newer tractors have?
