Dual wheel size for 16.9 x 30
Skoal022
I have a ford 4610 tractor. It has 16.9 x 30 tires on it now. I found some reasonably priced dual wheels the clamp on style with all the hardware minus the eyelets for 400 bucks. They comI have a ford 4610 tractor. It has 16.9 x 30 tires on it now. I found some reasonably priced dual wheels the clamp on style with all the hardware minus the eyelets for 400 bucks. They come with two used 16.9 fire stone tires. They are johndeere yellow and the sticker on them says 15x30 with a 10" band. My question is are my factory ford rims 15x 30? The 2 Firestone tires are not mounted on the duals. I plan on running a heavy 2800# 10' pull type cutter. I'm gonna load the inside rear tires with beet juice. I wanna stay under 10' wide. Will these duals work ok with the 10" bande with two used 16.9 fire stone tires. They are johndeere yellow and the sticker on them says 15x30 with a 10" band. My question is are my factory ford rims 15x 30? The 2 Firestone tires are not mounted on the duals. I plan on running a heavy 2800# 10' pull type cutter. I'm gonna load the inside rear tires with beet juice. I wanna stay under 10' wide.
1. Will these duals be universal from a johndeere to a ford?
2. I wanna run the same size tires, so is 15x30" the correct size for a 16.9 x30 tire?
3. I lost a diagram some one posted on here with the tire width. What are my options with a 10" band?
15x30 is the normal rim size for 16.9x30
tires. They will work fine. Have the same
size tire is more important than having
the same size rims.
