willjohnfrank
Thanks to everyone that helps out on a
daily basis to solve people's problems. I
was hoping someone could help me out with
my problem. I have a ford 3000 gas tractor.
When the tractor is running I cannot engage
the pto without grinding. In order for me
to use my shredder I have to engage it when
the tractor is off. When I crank the
tractor all is well and I can disengage it
at any time with no noise. To engage it
again however it will grind. At low rpm I
can throw the lever back hard but it doesnt
seem right. I have a friend of mine that
works at john deere and is a tractor
mechanic/ fabricator when he gets off. He
splits tractors all the time. I'm hoping I
wont have to do that but I was coming to
you guys to see if someone had a similar
issue.
I found this video and it is exactly what
mine does. This is after the person
replacing the clutch too. The poster said
that the tractor just eventually broke in
and it doesnt make the noise anymore.
https://youtu.be/wQLR-pGPuZE
issue.
