FORD 703 Loader (I need a new bucket, where to get 1?)
Simple enough in the Title. I need a new bucket. Mine is rusted out with holes all over. I bought it that way. It does work and sure I could weld it (If I had a welder). Is there a bucket out there that is a direct replacement that is not something I have to find via an antiques auction :lol:
Thanks for any info you can provide (Serious posts only please)
You'd be better off taking it to a "GOOD" welder and have it repaired on the tractor. I
doubt you'd find a "New" bucket! Jim in N.M.
What you find in an antique section may not be any better than yours. You can find a new, or newer good used, bucket but likely it will need to be fit to your loader how they pin on it different on different loaders. A good fab shop can use the sections of your old bucket as patterns and either rebuild it or build a new one like it. That could be a good time to add a common quick coupler set up, then it would be easy to swap between bucket or forks if you wanted.
