641 Ford lift
Larry Chaney
New User
Where can I find information on here about the draft and lift shim sizes and dimensions for the hydraulic lift on a 641 Ford tractor. I bought a set of shims from Zane but my dog ate it today. ANY help will be greatly appreciated.
Larry Chaney
(quoted from post at 21:41:39 04/21/20) Where can I find information on here about the draft and lift shim sizes and dimensions for the hydraulic lift on a 641 Ford tractor. I bought a set of shims from Zane but my dog ate it today. ANY help will be greatly appreciated.
Larry Chaney
hat shims?
mAYBE THEY AREN'T CALLED SHIMS.THEY ARE USED TO SET THE GAPS ON THE DRAFT AND THE LIFT. i HAVE FOUND THOSE MEASUREMENTS AND NOW I CAN MAKE A SET .
i STILL HAVE A PROBLEM WITH THIS LIFT. i MADE A POST ABOUT THE PROBLEM. IF YOU CAN HELP ME JMOR, I'D APPRECIATE IT IMMENSELY.
LARRY
JMOR, THIS IS MY PROBLEM
I was trying to set the draft and power lift on my 641 today. I was able to set the draft which I NEVER have used. When I tried to set the power lift,
I could not get enough gap to get Zane's shiM to insert for I ran ouT of threads. When I put the lift back on the tractor, the lift will go up all the
way or down all the way. I can't get it to hold a position in the middle. What can I do? Can I adjust around the draft since I never plan to use it?
Any help is appreciated!
Larry
Running out of threads on the adjustment coupling when setting (properly) the draft control adjustment is symptomatic of a bent draft control fork. Not uncommon.
Dean
(quoted from post at 11:59:31 04/22/20) Running out of threads on the adjustment coupling when setting (properly) the draft control adjustment is symptomatic of a bent draft control fork. Not uncommon.
Dean
Dean, I was able to set the draft without running out of threads. I ran out of threads when trying to adjust the power lift. Since I never use the draft, is there a way to adjust to get the lift working properly?
Thanks,
Larry
