703 loader assembly
laverack88
New User
A few of you helped me with questions about my ford 4000
recently. Im doing a full service on it now and i happen tp
come a crossed a 703 loader assembly. My question and
problem.... it comes as pictured... never put one of these on,
and im thinking its missing rear Brackets. I figure there must
be some type of clamps where it mounts up to the rear axle
housing. Thoughts? Possible to find them? Guy seems to
want top dollar at $1,000
On the extreme left in the picture there seams to be a bracket setting under the loader frame and the trailer floor. That looks like that could be one of the brackets you would need
I'm not well acquainted with Ford loaders, but that sure looks like something that would mount that loader. Hopefully someone more knowledgeable with loaders will chime in.
Matt,
Looks like only the LH rear bracket is on it. The brackets bolt to the rear axle with the large fender bolts (need longer ones with a loader, of couse). Make sure it has the front two brackets / plates to mount it to the engine cradle.
Here's a picture of my right rear mounting bracket. It's a U-bracket that bolts under the axle with the fender mounting bolts. I'm not sure your left bracket, as pictured, is right, should be U-shaped like the right one.
<img src =https://i.postimg.cc/prh7wSGN/Ford703-Rear-Mount-Bracket.jpg>
boss could you take pictures of the front mounting bracket van be an over all picture. just seems odd the have the big plate, and then 2 long attaching bolts. just seems to be alot of weight on long bolts like that in my piture of you look at it.
It's hard to get a good picture with the grill and other stuff in the way. I can't mention the web site but do a Google search for "Dearborn 19-97 & 19-105 Industrial Loaders - AO.pdf" (don't include quotes), download the manual, and look at the assembly instructions.
I have the original manual. I will post all the directions below in photos.
IDK why they rotate my images. Easy enough, just save photo and rotate or print it on paper.
