power steering leak, '70 4000
Henryford
New User
I have a leak coming from where the reservoir cover fits onto the pump body. After I run the tractor, there is pressure relief when I unscrew the filler cap. Seems easy enough to change out the O ring, but it seems like I have a pressure relief problem. Any thoughts would be appreciated.
There's a little rubber plug on top of the tan that acts as a pressure relief, wipe it off but don't remove it. You'll have to remove the tank to replace the o-ring and you need to change the filter while the tank is off. Make a scribe mark on the tank and pump housing to align them when you reinstall the tank, other wise the pressure line won't line up with the tanks fitting.
