I installed a new oil pump and rebuilt the motor. The issue that I have is oil pressure has been diagnosed with the pan off pressurized oil through the oil galleys no extreme leakage. However, the oil galley that lubricates crank gear and cam gear is shooting out oil through an 1/8" hole behind cam gear.
When the hole is plugged, it has 50 lbs. of oil pressure. With the hole opened, no oil pressure. The question that I have is, should the 1/8" hole have a reducer with a smaller hole? Or is could there be another issue?
