Bern
- Location
- Mount Vernon, WA
You said that you had the suction pipe out to make sure it was clean. Did you align it when you bolted it back in place? Ford had a special
tool to check the alignment with.
Try overfilling the rear axle by about 5-10 gallons and see if it starts working normally. If it does, the suction pipe is not seated in the
back of the transmission properly. This is about the only possibility left after everything that you've replaced.
