Ford 2600 Dash Wiring
Josh M.
Location
Northeast Ohio
I took my dash out because I wanted to get new bulbs, I only had 2 that worked. I was playing around with them and swapping bulbs around, now I have them hooked up exactly how they were and the bulbs are super dim when I turn the key on. I don?t know where the ground is for these lights so if anyone knows that would be great.
Ground wire is the black wire on the far right in the photo that's connected to the screw but could be a push connector that goes on the tab just above the screw
Thanks for the reply. I ended up finding that the 3 amp fuse was
blown. It took hours because if I detached the tach cable one light
would work so I was looking for a shorted wire and couldn?t find
anything, now that I have the new fuse everything works fine. Not
sure how the lights still lit up even with the fuse blown.
