graham_in_NJ
After completely rebuilding the lift, still no work. Replaced the piston o-ring and backup, replaced the o-ring (genuine CNH) on the unloader, still no lift. Unloader movement was smooth. When I put the lift cover back together, I left the unloader valve at the "pump oil into the piston" position which was forward, furthest from the plug. Adjusted linkage per the shop manual. So, when moving the control to the lift position, it should have lifted. Guess I need a pressure gauge at this point....
Then there's the generator. Another thread. Later.
This has been quite a money and labor pit......but it runs great
