Company Logo Shop Now
Order Ford NAA Parts Online
NAA distributor gear removal
Olliejunkie
04-11-2020 11:54:15
Trying to get the pin out. This one is solid not a roll pin. I ground the ends and now I cant see the pin anymore. It may still be saleable but much more and I will need a gear. I'm about ready to order one.
Olliejunkie
04-24-2020 16:23:57
 Re: NAA distributor gear removal in reply to Olliejunkie, 04-11-2020 11:54:15
The new distributor seems to work good. I set it so the points were just starting to open at tdc 1. It started up then I turned it clockwise until it labored slightly. Now I have discovered there is no petcock in the block and its seeping water out of the rusty hole. I will fix that later. I need to check the valves next. I'm thinking of adjusting them at .015 cold. Any suggestions. I dont really want to do it hot with the tank and muffler.
JMOR
04-17-2020 23:09:17
Quoting Removed, click Modern View to seehe, he, he! what did everyone tell you about keeping original?
Olliejunkie
04-17-2020 18:18:09
Got my new dizzy today. It has a sticker from cap to body that says warranty void if removed. Now how am I going to install it without removing the cap besides I need to clean and check the gap. Lol.
Olliejunkie
04-12-2020 10:21:06
Thank you for the info. I think I will order one. Had I found one this cheap a few weeks ago I probably would've got one instead of trying to rebuild it. Live and learn.
Gene in Mi
04-12-2020 09:49:25
Anyone have experience with aftermarket dizzy?
My experience was the same as yours. I could not get the solid pin out. I ended up damaging the gear.
A new or rebuilt distributor got me running, BUT the rotor was hitting the contacts inside the cap! I had to massage things to make it work. Give the replacement before installing to check your new one.
Electronic ignition is supposed to tolerate a sloppy distributor shaft, which is what I had. I did not swap over because my NAA is still 6 volts and at the time there was not a 6 volt EI.
Olliejunkie
04-11-2020 22:11:15
I found a aftermarket new distributor for $93 with free shipping. Looks like it comes complete with cap ,rotor and all. I already have more than that in this one and looks like a gear will be another $50. Anyone have experience with aftermarket dizzy?
Olliejunkie
04-11-2020 17:58:16
That's a good idea too. If I find a used distributor I will do that.
Hobo,NC
04-11-2020 17:48:02
They are so hard to support I made a bed to lay them in so I can whale away at it, it works quite well...
Olliejunkie
04-11-2020 17:06:25
Thank you. I'm in Oregon but that's not a bad idea.
catalina0029
04-11-2020 16:27:16
Where are you located? I'm in SW Michigan and I can put it in the lathe and machine the gear off.
Olliejunkie
04-11-2020 14:04:30
Well I see a crack started so I guess a new gear is in order. I should've just bought a new distributor. Still not sure how I will get this one off. Looks like 850 is a different animal.
Olliejunkie
04-11-2020 13:37:47
I may need some soon. I am beyond tired of this tractor. I have no more patience right now. Makes it hard to get things done.
JMOR
04-11-2020 13:36:31
Quoting Removed, click Modern View to seeOh, they are tough! Not sure Henry ever wanted us to remove them! :)
nashranch
04-11-2020 13:23:56
My neighbor still has that 850 motor with the hole in the block. He is willing to sell parts off it.
Olliejunkie
04-11-2020 13:06:07
I ground it with a dremel tool. Then I heated it and hit it where i thought it was. Seems i have fought with these solid pins before.
JMOR
04-11-2020 12:54:54
Quoting Removed, click Modern View to seeHave used a grinder, too and the difference in heating will sometimes bring out pin outline.
Olliejunkie
04-11-2020 12:51:36
Mine is so beat up now I cant see anything. I will have to get a small file and clean it up. Today is not working out. Maybe later. Probably would've been cheaper to buy another distributor.
JMOR
04-11-2020 12:47:58
Quoting Removed, click Modern View to seeI have been able to see fine line around pin with good light & magnification.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
