3000 lift issues
(quoted from post at 20:47:48 04/09/20) 3 point lift will not work, but remote hydraulic engages. Help please
Well the fact that the remotes work says that the pump is working. Beyond that we don't have enough information to troubleshoot the 3 point problem.
Is this tractor new to you and the 3 point has never worked since you got it, or have you had it a while and the 3 point lift used to to work and now it doesn't? Did it gradually start having issues and finally stopped working altogether or did it work fine up until the point where it suddenly didn't work at all?
Exactly what setup does it have for the remotes? Does it have a diverter valve mounted on the top cover with a separate control valve for the remotes, or does it have a remote valve mounted where the factory blocking plate was originally located?
Does the behavior change at all if you switch the selector lever between draft and position control modes?
Yes, 3 point used to work fine, tractor has been setting up for several years,( I got another tractor). I
decided to get it back and running. The remote is on the top cover plate with a diverter valve. Was hoping it
would be something simple, but was afraid I might have to take it apart.
