ford 2120 question ???
tazer500
New User
ok so after some years of the little 2120 just sitting I was finally able to get to a friend of mine to split the tractor to what was going
with in slipping. well we found the clutch to be bathing in oil, keep in mind this tractor has been sitting up for about 4-5 years and came with farm I bought and then sit about 4-5 years before I ever got around to taking it I know, I know lol
anyways the clutch is shot but the problem we are trying to track down is why is there so much hydraulic fluid in bell housing.
im needing to know what the three lines inside are called so I can look up the part just in case they are leaking. we are having it pressure tested first.
here,s the pics
[/img]
(quoted from post at 14:06:48 04/10/20) ok so after some years of the little 2120 just sitting I was finally able to get to a friend of mine to split the tractor to what was going
here,s the pics
[/img]
heres what the poor clutch and plate lloks like
That manifold is #35 in the link below, but for some reason the part is not listed.
The brazing on the ends of the tubes does not look factory, and is most likely the source of your leak.
Manifold
(quoted from post at 17:49:14 04/10/20) That manifold is #35 in the link below, but for some reason the part is not listed.
Manifold
Thanks I'll see what I can find to replace it with lol
Looks like the same manifold is in the drawing for the clutch & clutch case at the link below, and it's labelled #31 in that drawing:
[u:c7166a32f5]Clutch & Clutch Case[/u:c7166a32f5]
And that parts drawing does have a part number for it, which is SBA340702380. But unfortunately that part appears to be no longer available new. tractor-part.com does list a couple of salvage yards that claim to have a used one and even a place that claims to have a new one. I would contact those places directly to see if they really have them and what price they're asking.:
[u:c7166a32f5]Tractor-part.com search for SBA340702380[/u:c7166a32f5]
