Company Logo Shop Now
Order Ford 4000 Parts Online
4000 diesel won't start.
Steak Sauce
04-10-2020 10:47:51
Hey guys! I have a 62 model 4000 that has me stumped. It sat the winter and now won't even try to fire. Has fresh fuel to the injectors, and plenty of fuel to the pump. I'm thinking it might be either an injection or a pump issue, But looking for some more input before I start pulling things apart.
showcrop
04-11-2020 04:29:20
 Re: 4000 diesel won't start. in reply to Steak Sauce, 04-10-2020 10:47:51
Is your battery up? They will crank at just below adequate cranking speed all day and not start. I ran mine out of fuel once. I left it and went and got another tractor to finish the job then came back the next day with booster cables.
Steak Sauce
04-11-2020 20:04:31
 Re: 4000 diesel won't start. in reply to showcrop, 04-11-2020 04:29:20
Battery is new. Charged it after primeing the system, still no luck.
sunbeam
04-10-2020 14:05:20
If is not a select o speed pull start
Steak Sauce
04-10-2020 17:55:34
 Re: 4000 diesel won't start. in reply to sunbeam, 04-10-2020 14:05:20
SOS model.
Al Baker(pumpman)
04-10-2020 13:55:31
see a couple a week on average that have locked up from setting. Some from just setting over the winter. Simple repair. Al
Steak Sauce
04-10-2020 14:08:16
 Re: 4000 diesel won't start. in reply to Al Baker(pumpman), 04-10-2020 13:55:31
Can they be freed up without opening them up?
Dieseltech
04-10-2020 13:00:53
Is there white exhaust smoke? If so injection pump is getting fuel through the injectors, but compression heat is not high enough to burn fuel. No smoke means no fuel in chamber. Did you try the Thermostart, if engine has one? Used correctly they start a cold diesel well..
Steak Sauce
04-10-2020 13:20:34
 Re: 4000 diesel won't start. in reply to Dieseltech, 04-10-2020 13:00:53
No smoke when it turns over. Primed the pump and lines to the injectors. The lines where dripping fuel when I bled the air out.
Steak Sauce
04-10-2020 11:40:09
Took the air cleaner assembly off and all was clear.
Fordfarmer
04-10-2020 11:08:35
Diesels need air + compression + fuel. Check your air filter. Could have had rodent plug it up?
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
