Hi all-
Over the past year or so Ive purchased all parts from this website (much appreciated).
This is a 12v with generator.
I believe I have everything wired up according to what I found here on YT.
The problem I am having is the key turns but will not start or shut off the motor.
I disconnected the wire (shown in the pic) to see if this did the trick. It does not but when I touch the wire (which has an in-line bulb) to either side of the terminal block, the bulb lighrs up and I use the push button to start it....using no key at all!
Help!
P.s. I simply flood the tractor out to kill it. Sucks but works
Help!
