961 water pump replacement
Phord961
New User
Pulled the waterpump off of my Ford 961 gas. Small dribble of coolant coming out of the bottom mounting bolt hole. In 15 years of use never had issue with a leak, but should I be concerned now?
No, don't worry, it is normal. Just put some plumbers pipe dope or teflon tape on it at the end. A tip, just in case you will be removing the T'stat housing as well, is to be sure that the T'stat is seated in the groove in the block before putting the housing back on. If it is not in the groove it can result in a broken housing.
