David Lewis
Guys, My 860 ran great all last year, but started misfiring about a month ago, and now sometimes it just won't start.
I have cleaned, rebuilt and adjusted the carb, cleaned the air filter thoroughly, checked gas flow from the tank.
I put in new Autolite 437 plugs, checked the points for spacing, made sure all wiring connections are tight, charged the
battery, gas is clean, and the compression is good.
But sometimes it just will not fire on startup.
Could it be condenser, coil, or what.....can't think of anything else.
Seams like it could be a weak spark issue, but I just can't figure it out.
Your experience will help - it always does! What do you think is wrong?
