Hiddenvalley627
Acquired a 3000 Ford diesel that needs some TLC. It has obvious following issues.(1). Injector pump has leak that seems to come from under the pivot/throttle arm hooked to the throttle rod. (2) Power steering doesn't work. Have ordered filter but need advice on filter install. Dont expect filter change to cure problem so advice on next options appreciated. (3) Where would serial number be located? (4) Anybody have knowledge of problem using a NAPA fuel filter in that the O ring causes restriction of fuel flow to IP? I had a problem with Napa fuel filter O ring restriction on 6610 Ford in past!
