Getting parts together to repair a broken PTO brake band on a 6610 and fix the leaky lift cylinder while I am in there with the top off. One thing I have come across is the gasket for the top cover. When I look up the part number that the 6610 part manual calls for, it says it fits a 5000 and 7000 as well, but if I look up the part number for those tractors, it shows as only fitting those. The 5000 and 7000 lift cover gaskets are much more readily available than the one for the 6610 and with everyone in quarantine, it would be a lot easier to order one of those straight to the house.
Does anyone know if the 5000/7000 gasket C5NNA967B will work on a 6610 (it calls for E4NN967AA, so almost the same part number too). Also, is the parts book correct that the piston uses the same backup ring and o-ring for the piston?
Hurst
Hurst
