66 Ford 3000 diesel with Simms injection pump. Recently adjusted top end, new regulator, switch, batter, replaced all fluids, flushed radiator. When starting, even with thermostart, it puffs a lot of white smoke and won't start. If I spritz starter fluid it cranks right up and runs very well, strong, no smoke.
Thoughts on why it's so hard to crank? I'm not sure how to adjust the Simms injectors but it seems that it would run rough if the timing was off?
