Company Logo Shop Now
TractorLinks.com
Ford Tractor Blue Paint Color
lfc
03-26-2020 10:44:21
I'm getting ready to paint my 6610-II, and want to use a two-part single-stage paint for better longevity. I know there are seemingly a lot of different Ford blues out there, so I bought a can of official CNH Ford blue spray paint for comparison. I also ask my dealer for an old blue part, and they sold me a remote PS reservoir cover off a 1000 series which I assume is an old part, but I'm not sure. The spray paint matches the cover well, and also matches some protected areas on the tractor. However, these blues all seem to be a bit darker than what I think of as Ford tractor blue and all seem darker than my other faded 10 series tractors. I decided to order a gallon of Ford tractor blue from Transtar/NAPA, and the color is definitely lighter and greener but is closer to what I consider Ford tractor blue. I know printed brochures are not a good guide, but my 10 series brochures seem darker than my old 2000/3000/4000 brochures. So, my question is did Ford tractor blue get darker over the years from 1965 to before the switch to NH Blue? I have a gallon of expensive blue paint that I need to decide if I can use or if it will haunt me that I used the wrong color.
Tim PloughNman Daley
03-28-2020 03:33:26
 Re: Ford Tractor Blue Paint Color in reply to lfc, 03-26-2020 10:44:21
FORD TRACTOR THOUSAND SERIES BLUE PAINT CODES – PRE–NEW HOLLAND
My 1969 Special Parts Catalog lists the Ford Blue paint, after ’63 as M1J-1639-SE
CNH sells their IRONGARD brand as p/n 9613386DS, 63-00 BLUE, close match and should be the same as the 2nd one on list, M20J11639A #8486.
NOTE: Equipment Dark Blue is a darker shade.
FORD THOUSAND SERIES PAINT TEST; cnh 100:
Someone sent me these a while ago...
Ford Tractor Blue (1962)------------------------------12720
Ford Tractor Blue (1963-1965) - M20J1639A-------------12809
More Ford Tractor Paint codes
Ford Beige--------------------------------------------33186
Ford Gray---------------------------------------------30570
Ford Gray---------------------------------------------32663
Ford Gray (1948 & 1954)-------------------------------32675
Ford Yellow-------------------------------------------82536
Ford Light Yellow-------------------------------------82549
Ford Red----------------------------------------------2833
Ford Red (1947)---------------------------------------70075
Ford Light Red----------------------------------------72598
Ford Equipment Dark Blue------------------------------12908
Ford New Tractor Red----------------------------------71969
Ford New Tractor Silver-------------------------------33442
Ford Tractor Buff-------------------------------------81339
Ford Tractor Gray-------------------------------------30448
Ford Tractor Gray (1965) - M20J1750-A-----------------32571
Ford Tractor Gray (1965)------------------------------32571
Ford Tractor Green------------------------------------42940
Ford Tractor Yellow (20J3132A)------------------------82179
Ford Tractor Yellow (New) (M2J5394-A)-----------------82291
Ford Tractor Orange Red-------------------------------71346
Ford Tractor Vermillion (1949)------------------------3155
Ford Tractor Vermillion-------------------------------70205
Ford Tractor White------------------------------------8712
Ford Tractor & Implement Buff #1640 (1967)------------22914
Ford Tractor & Implement Buff (1967)------------------4068
Ford Tractor & Implement Buff (1967)------------------4119
Tim Daley(MI)
03-28-2020 03:30:42
FORD THOUSAND SERIES PAINT TEST 100:
Tim Daley(MI)
Tom in Mo.
03-27-2020 13:03:03
Try this. Search with your own zip.
https://www.ppgpaints.com/store-locator
Tom in Mo.
03-27-2020 13:00:35
Agreed on poor availability. I have four auto parts stores in town but had to drive to a different county to get it. Auto parts stores go with whatever corporate tells them.
Tom in Mo.
03-27-2020 05:15:33
According to this one chart (and there are many) it looks like there are several blues to choose from.
https://paintref.com/cgi-bin/colorcodedisplay.cgi?make=Ford&model=Tractor
Tom in Mo.
03-27-2020 04:23:11
I have had very good results from two part PPG paints (for other makes). Sorry, no PPG number to give you.
lfc
03-27-2020 12:14:08
 Re: Ford Tractor Blue Paint Color in reply to Tom in Mo., 03-27-2020 04:23:11
Tom,
I looked around on the internet for a while trying to find two references that told me the same story, but I didn't have much luck. I saw the color in your link listed under Ford Tractor Blue, but that color doesn't look that close, at least on my monitor. I have a PPG dealer about two miles away but they are closed to the public - I guess you have to own an official shop to go there. Seems like a bad business model.
lfc
03-27-2020 03:48:09
Thanks everyone for the replies. I went back out yesterday and painted a slightly larger piece with the new paint, and I think I've determined now that the paint is not a good match. It has way too much grey. Whenever I can I need to talk to NAPA and see if they can either add more blue to this paint or mix me one of their "stock" colors. There was one that was fairly close, just a little too dark. Maybe mixing the two together might work. I wish we still had the paint store in town where the man that had run it since the 50's could mix just about anything you needed by eye.
Ultradog MN
03-26-2020 14:15:13
I think the same blue was used from 63-99.
I have found different brands and types of paint look quite different when wet but all dry the same blue.
I understand you wanting to get it right as I'm in a similar quandary about the light gray that was used with the blue. The CNH paint seems a bit too tan colored to my eyes.
But the guys here and a couple of old timers at Ford dealerships say it is the same tannish, off white gray that they remember when the tractors were new.
Bern
03-26-2020 20:16:05
 Re: Ford Tractor Blue Paint Color in reply to Ultradog MN, 03-26-2020 14:15:13
The gray looks more tan when it's wet, but gets whiter as it dries.
Ultradog MN
03-27-2020 10:19:05
 Re: Ford Tractor Blue Paint Color in reply to Bern, 03-26-2020 20:16:05
The sad part is I painted these rims a couple of years ago. Used the "correct" gray but thought it was wrong so I concocted my own color and second coated with that. I left the inside the right color as it's hidden and doesn't matter.
Wish now I had done it opposite...
Sean in PA
03-26-2020 12:12:41
Even old original parts that have not been exposed to the sun can change color over the years.
Bern
03-26-2020 11:23:00
This is a subject that always seems to stoke some controversy here on this board, but the official NH position is that Ford tractor blue has been the same from 1963 until 1999 when they started to blend in some more purple. That has been my personal observation as well, I have never detected a change in the hue over the years mentioned.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
