Need used 6 volt generator for 800 series
I have several professionally rebuilt 6V generators to fit 53-64 Ford gasoline tractors.
No disappointments and they ship in a USPS Priority Mail box.
Email is open.
Dean
Someone changed it to a 12 volt alternator. The wiring was wrong and the alternator pulley does not line up and the belt tightened are is tied with baling wire ? I put a 6 volt battery and 6 volt coil on it. I disconnected the alternator wire. I want to put it back to 6 volt. All the wires are still there for the generator. The generator bracket and arm I think are correct.
I really don?t want to spend the money for a new or rebuilt unit. I?d like to find a used one.
(quoted from post at 08:27:29 03/19/20)
Email is open.
Dean
Does your copy of your response actually show your email open, Dean? My copies of it don't show email access for you in either modern or classic view.
I have a used 6 volt generator with pulley and voltage regulator from a 1957 600. Was charging when I removed it. I have reasons I wanted to switch to 12 volt. I responded to your other thread.
Where are you located? I have a rebuilt 6 volt generator that was on my NAA. It works fine, just couldn't find voltage regulators that would work for more than a couple of weeks if at all.
