Everything is cold, but the meter reads high and bounces around. I can't remember but I thought I read somewhere that you could oil the bearing on the back of the cluster. Is that correct? The cable rotates super easy.
On another note I was trying to check the RPM with my multimeter, I set it on RPM 4str 3cyl and put it on the coil power and switch ground, but it reads really high, like 5k rpms. Am I missing something?
