Ford Tractors Discussion Forum |
Ford 850 starter issue?
Author |
[Modern View] |
Dacaseguy
02-26-2020 15:10:51
Ford 850 starter issue? I am helping a neighbor on his 850 Ford that was parked about a year ago. We got a new 6 V battery and hooked to the cables and got nothing from the starter we tried putting a jumper cable direct to the starter and all the starter done with spin did not engage. It seems to be a starter issue could it be The Bendix is stuck and needs Freed up
showcrop
02-27-2020 05:30:30
Re: Ford 850 starter issue? in reply to Dacaseguy, 02-26-2020 15:10:51
Oilite bushings need oil?
George by Geneva, NY
02-26-2020 17:23:09
Time for a tuneup on starter. Struggled with 871 to start last Sun. Finally ran, moved to work garage, starter came off. Ugh. lots of dirt mixed with fine copper powder around brush end. Shaft/bushings bone dry---no lube of any sort, probably the source of the problem. So, no wonder it took lots of battery and turned slow to start. Commutator smoothed, new brushes, getting painted now and will be lubed when assembled. Should work good then. Let's be real here, these machines are 50 plus years old and starters seldom get care, just replaced. I started doing my own repair years ago because of too many failures of "rebuilts", usually showing lack of lube. For lube I use a mix of chassis grease and ATF, mixed to a slurry. Bendix can get stiff with old lube in the clutch unit. Any old engine I get doing starter clean and lube is near first repair it gets.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
