COclodhopper
New User
I have spent way too much time messing around with this carb. Never had this degree of problem from other tractor carbs. New to me tractor, was running very rich when I bought it, but was guessing a hole in the float by the way it was acting.
Now, Rebuilt carb, passages are clear, New float, new needle, seat looks fine, adjusted the float down to increase force on needle, I am sure float is not catching on the bowl, tried some different spring configurations to help the float out..... still flooding and if not flooding running way too rich. I have the idle screw shut off just to get it out of stumble stage but still too rich. I haven't even started to determine if the power boost is having issues.
I am starting to think the issue may be somewhere else. I am not used to having a fuel pump, could that be failing and pushing too much pressure to the carb? What am I missing?
