The General
New User
I'm sure this has been answered 1000 times before, but I'm new to the forum, so please forgive me.
My 1953 Ford Golden Jubilee Lift Arms will 'bounce'. What I mean by that is: They will lift and lower fine, but while trying to hold a heavy object (like the bush hog), they will sag some, then 'jump/bounce' back to the desired position. At the rear of the bush hog, it will jump about 2 inches....
I just did a cleanout/repair of the Hydraulic cylinder (new gaskets, O-rings, cleaned it out) and it still does it. New gaskets on lid cover too. There's really not a lot of parts that can be changed...
I still need to peak inside the inspection ports while holding the load to see if its leaking fluid anywhere, but I'm sure that this is a 'common' problem and that it's been solved by many members here before. Even if it is leaking inside, I'm not sure what to change next!!
Has anyone solved this yet and if so, what was the cure?
Thanks in advance for the help!!
-Mike
-Mike
