Company Logo Shop Now
Order Ford 3000 Parts Online
Ford 3000 steering getting harder to turn
Copperhead don't play
02-10-2020 13:15:34
Have had this Ford for many, many years, but this winter it became hard to turn the steering wheel both ways. Lots of flop in the front tires. Where should I start first to solve/repair this problem? Thanks, Copperhead
GB in MT.
02-12-2020 11:28:54
 Re: Ford 3000 steering getting harder to turn in reply to Copperhead don't play, 02-10-2020 13:15:34
[size=18:e4be62a59a][/size:e4be62a59a]
" Do you have any advice on removing the steering wheel?"
Yup.....this is what I do on steering wheel removal.
Use a 3 jawed puller for a 3 spoke wheel!!
Took about 25mins...start to finish, on my 3000!!
Works great!!!
Gary
:wink:
02-11-2020 08:00:05
Not a hard job either. Worst is pulling the steering wheel and tin off to get at the column. Thanks for the advice Ultradog.
The nut on the top of the steering is 3/4 rusted away, Do you have any advice on removing the steering wheel?
Ultradog MN
02-11-2020 12:48:08
 Re: Ford 3000 steering getting harder to turn in reply to Copperhead don't play, 02-11-2020 08:00:05
I made this contraption.
It's out on loan at the moment or I'd get some measurements for you.
Works good.
sunbeam
02-10-2020 18:41:24
The first thing is the spindal thrust bearings
Ultradog MN
02-10-2020 15:06:18
Assuming this is a manual system and not power steering?
We don't know what you've done so far so I would grease the whole front end and add 90W to the steering box.
That done I would jack the front end up and see how it steers with no weight on it.
Could be dry upper bearings in the steering box, could be shot/gone thrust bearings in the spindles. Floppy steering might be sector gears need adjustment and or ball joints worn out. The entire steering system on those are pretty simple but they do wear out, even if kept lubed. Parts are not expensive even to rebuild the whole shebang - upper thrust bearing in the column, thrust bearings and bushings in the spindles, tie rod ends, etc.
They steer pretty good when they're up to snuff.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
