ScottZ_Ford2120
New User
I am the new owner of a used 1990 Ford 2120 tractor, 4x4, w/HSS 4x12 transmission and loader. Its the first tractor I've owned/maintained, but I am very mechanically inclined and intend to do most maintenance and repairs myself. Bought the tractor with about 850 hours and have put another 50 or so hours on it before my first breakdown.
It is leaking hydraulic fluid from the solid pipe that runs from under the hydraulic pump back to a valve for the loader controls. That hyd pipe is part#: SBA-340702120. Can't find it new, now searching salvage yards. If no luck, I will have to repair the pipe somehow. The hydraulic fluid that leaks is a milky butternut color. So there is water in the system and I need to flush and replace all the fluid.
I've purchased a Ford 2120 service manual, but haven't received it yet, so I'm flying blind at the moment.
What I've learned so far from reading this forum and my other research and my current plan:
0. Replace/repair leaking pipe
1. Run the tractor for a while to warm/mix the oil.
2. Drain oil, remove filter and empty oil from the old filter.
3. Put old/empty filter back on.
4. Fill with new hydraulic oil (how much? mix oil with diesel fuel?)
5. Run tractor, cycle all hydraulic cylinders (loader and 3pt lift).
6. Repeat steps 2-5, 1 or 2 more times, with the hope that after each change the oil become more clear
7. Put new oil filter on and fill with Ford/New Holland 134 Hydraulic Oil.
My questions:
What is best approach to flushing and replacing the hydraulic fluid?
Comments or suggestions on my plan above?
Other Tips and tricks for the do-it-your selfer, so I don't end up with oil all over my garage floor?
How do I prevent air from entering the system or must I bleed the air after the final fill of oil? If I must bleed the air, how is that done?
Thank you,
Scott
My questions:
Thank you,
Scott
