Company Logo Shop Now
Order Ford 841 Parts Online
Ford 841 Power Steering Cylinder
jr841
01-25-2020 19:49:04
My right power steering cylinder is leaking because shaft is bent. Do these aftermarket cylinders made for left or right work all right? I've got to see if my shaft size is a 1/2" or 5/8". Do you have to have the same shaft size to make it work?
riveroadrat
01-26-2020 12:04:57
 Re: Ford 841 Power Steering Cylinder in reply to jr841, 01-25-2020 19:49:04
I've heard you should use same size but I've seen them mixed.
CTPhil
01-26-2020 07:02:42
I've never bought an aftermarket cylinder but have looked into them fairly extensively. All I can say from my searching is that not all aftermarket cylinders are equal. Some work fine and some get horrible reviews.
Ultradog MN
01-26-2020 02:41:38
I've had a set of the aftermarket ones on my 3000 for 10 or 12 years. The same cylinders were used from 1955-1983 and maybe beyond. The only problem I've ever had with them was getting the lines to seal at the fittings without leaking.
I ended up using a Locktite product that's made for sealing hydraulic lines. Cleaned the fittings real well with lacquer thinner then applied a couple of drops of the stuff and assembled. I let them sit for a day to dry/cure before starting the tractor.
All the ag models use the cylinder with the 1/2" rod. Only the 62-64 light industrials and some of the 3 cylinder tractors like 3400 use the 5/8" rod.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
