Ford 4000SU Serial Number
Steve in IL
Any thoughts on decoding the below two lines? I thought
there should be three lines of codes/numbers.
The tractor is a original looking 4000SU, with gas engine,
independent PTO.
Thanks.
Which side of the tractor did you find those numbers? They look like they are the date code and assembly spec of the transmission itself. Try looking on the same flat spot on the oppposite side of the tractor for other numbers.
