Hello everyone, I have a new problem that I'm hoping someone can help me with. Recently I was trying to fix a few fuel leaks on my tractor so I replaced the fuel shut off valve along with a new line to go to the valve to the filter, a new filter and four new injection lines. Everything for the most part went smoothly but now after bleeding everything and running the tractor, it seems my idle up to about 1200 rpm isn't smooth. It seems like a cylinder isn't firing or timing is off. Even though I didn't take the pump off, so the timing should still be good, I tried adjusting the timing both ways with the same miss at idle. You can hear it in the exhaust and see the exhaust cap flap every time the cylinder misses. As soon as you throttle up past 1200 rpm, it smooths out and you would never know. There is no excess smoke at idle and I had both the injectors and pump rebuilt a year ago. I dont want to do any damage to the motor, so I would like to fix this issue. Thanks for your help.
