Is this the correct timing mark?
338ftw
Manual says 5 degrees btdc. Is that this 5 degree mark on the flywheel?
The arrow on the housing is actually pointing to the degree symbol, not the 5 degree line, so it's about a half a degree off. It is the long line on either side of the 5 that is the actual 5 degree line.
(quoted from post at 07:12:17 01/12/20) The arrow on the housing is actually pointing to the degree symbol, not the 5 degree line, so it's about a half a degree off. It is the long line on either side of the 5 that is the actual 5 degree line.
I m just trying to make sure that s the mark I should be shooting for when timing the tractor.
