DJ53jubilee
New User
Hello ALL,
I am having an issue with my Jubilee. I had an issue with it not starting 1 day. Weak spark seemed to be the issue. New plugs, rotor, cap, points, coil and resistor. No luck. Decided to take out the resistor and it fired right up. Put the resistor back in died right away. Put back in the old coil same thing ran fine without the resistor.
About 25 hours of run time later i am having issue with it dying after running maybe 15 mins. After looking around on this forum it seems as if my coil might be going bad. I have jumped the coil directly to the battery to eliminate any wiring issues. same results. Thought it could be a gas flow issue removed the carb cleaned it out. I also took off drain plug under carb and the gas flowed out strong. Emptied out a gallon just to make sure it cleared the bowl and was dumping from the tank.
Do i need to replace the coil and resistor again? im afraid to use a coil without the resistor in case i need to remove the resistor again to get it to run.
Any thoughts on what to do or check next?
Thanks
Dennis
Thanks
Dennis
