Ford Tractors Discussion Forum |
Hydraulic fluid for 850?
Author |
[Modern View] |
338ftw
12-31-2019 14:27:28
I had to drain mine when I split the tractor. I m pretty sure what came out was ATF. It was red in color and smelled like it. Is that right or should I be using something else?
Larry NCKS
12-31-2019 20:26:07
Re: Hydraulic fluid for 850? in reply to 338ftw, 12-31-2019 14:27:28
likely the PO put wrong oil in. Most UTF I know is brown green yellow colored.
338ftw
12-31-2019 16:56:35
Is that utf red or did The po actually put atf in the system?
showcrop
12-31-2019 16:16:43
It depends on where you are, (humidity) and hw much use it will get. UTF, which you need if your tractor has clutch packs or wet brakes, which an 850 does not, will absorb moisture from the air, which is not a problem if you get the oil hot enough 3-4 times a year to make the water evaporate. Plain hydraulic oil does not tend to absorb the moisture so you can get rid of the moisture by draining it off the bottom once or twice a year.
old
12-31-2019 15:06:01
UTF that meets the Ford 134D spec.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
Looking for two coulters and mounting brackets for a JI Case centennial plow
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
