Company Logo Shop Now
Order Ford 600 Parts Online
8670 Genesis hydraulic remote only 600psi on left side ?
Alvin 41
12-27-2019 16:13:14
8670 has 4 remotes but the bottom ,most used, has only partial pressure on one side . One above it works ok but also bumps up 3 point when lever pulled . What's going on ?
chevytaHOE5674
12-28-2019 19:22:42
 Re: 8670 Genesis hydraulic remote only 600psi on left side ? in reply to Alvin 41, 12-27-2019 16:13:14
Going with a blown o-ring in a shuttle spool as well.
Larry NCKS
12-28-2019 12:51:20
Those look really complicated, Bern. Glad I've yet to have to mess with that part of it.
RickB
12-29-2019 12:30:12
 Re: 8670 Genesis hydraulic remote only 600psi on left side ? in reply to Larry NCKS, 12-28-2019 12:51:20
I went through a few valve stacks back in the day. They arenít really that bad. I agree that is the first place to look.
Bern
12-27-2019 18:11:37
You most likely have blown o-ring(s) in the various shuttle check valve passages within the control valve itself. This circuit provides the pump with the command signal it needs to generate the proper pressure.
Look at part # 2A, 2B, 4A, 4B, and similar seals in the link below.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
