Ford Tractors Discussion Forum |
Will it fit easily?
Author |
[Modern View] |
docmirror
12-10-2019 20:01:58
I just about wore out my steering gear on the 8N. I have a Wagner loader and bucket on there, and as we all know, it's not made for that stress. I do light bucket work, and some easy grading. I found a Ford 840 about 1956. It has the optional power steering, with the belt driven pump up front like an old Falcon, and two hyd rams on the sides. According to my buddy at tractor shop, the Wagner model III(hyd tip bucket, down pressure main rams) can be unbolted from the 8N, and bolted on to the 800 series with no welding, bending, etc. He said if I'm unlucky it won't have the spline drive on the crank snout for hyd drive but that can be installed in a few hours. I want to do this easy, because I won't have a welder or torch handy where I do the swap. Also, it's going to be winter, and up in the mtns, so may have some cool weather and light snow, so I want this to go slick as possible. Will it fit easy? Anyone done it from 8N to 840 or 860?
docmirror
12-11-2019 13:08:43
Re: Will it fit easily? in reply to docmirror, 12-10-2019 20:01:58
Yup, found it. Got all I need except some hardware. I'm all set. :D
Hobo,NC
12-11-2019 12:03:41
Hobo,NC
12-11-2019 12:02:37
Look under.
Ford 800 Parts
Category: Hydraulic System
docmirror
12-11-2019 11:29:43
Wow, this is perfect info. Thank you a million. Working off page 10 of the print, my loader did not come with angle brace #33, so I made my own. Lucky for me, I made them about 3" longer than needed, so I will have to drill holes once I get it lined up to fit the 840. I should have enough material on both sides to get it fitted. Working off page 11 of the print, I will need the spline hub, bolts and shaft to switch over from my current 8N hardware. I'm sure I can get that here on this site. May not be perfectly plug and play, but not bad enough to slow me down. I notice one other slight change from the print to my loader. The print shows two plate bumper behind, and below the hyd bucket ram. My until has one plate, but is wider than those two plates. I'm pretty sure this was just a running alteration, and has no factor in the functioning of the unit on either chassis. Perfect info, and very helpful.
Hobo,NC
12-11-2019 05:08:43
I know it will mount to a 600 series a 600 is 3 to 6" longer I don't remember the exact number. Look at your rear mount you will see its longer than it need's to be for a N unless someone cut it off... On the front bracket the only difference would be where it fits over the axle pin retaining bolt. I would wager it will be a EZ swap have a drill and some new hardware on hand... As far as the loader pump drive you would need to research how the pump drive mounts to the 800 front crank pulley and what style they use. https://forums.yesterdaystractors.com/viewtopic.php?t=1391027&highlight=pulleyLike a N it needs a different front crank pulley retaining bolt its been a long time since I have been there memory is somewhat lost... Other than these two issues it should be plug and play... https://forums.yesterdaystractors.com/viewtopic.php?t=1102458&highlight=pulley
Kirk-NJ
12-11-2019 01:01:49
Here is the print out of the pages of the wagner 3 loader You will have to drill holes in you front axle carrier. You will need the adapter that bolts up to the front pulley (not the same as what's on your N tractor). The frame for the rear has different holes for mounting on the later style tractor.I should mention that the correct size bolts must be used to mount the adapter to the pulley.
Kirk-NJ
12-11-2019 01:08:26
Re: Will it fit easily? in reply to Kirk-NJ, 12-11-2019 01:01:49
Lets see if this is clearer
docmirror
12-10-2019 20:57:51
Thanks guys. That's what I was thinking as well, but didn't know the particulars. This makes sense. There would be no reason to have the same chassis geometry as the 8N. Before I drop coin, I'm going to take some specific measurements of the rear fender mount, and the distance from the three bolt front lower mount back to the fender mount. It looks like I'm going to have to figure out something else.
strum456
12-10-2019 20:38:34
If memory serves, the 8n is a little narrower between the fender bolts, which are also used for the rear high lift brackets; plus the wheelbase difference.
Sean in PA
12-10-2019 20:32:51
The 840 has a longer wheelbase than the 8N, so I doubt that the mounting points would be the same distance apart. Many loaders from that time frame could be mounted to different tractors but you needed the correct mounting brackets for the tractor you were mounting it to. But to be sure, measure the mounting points on the 8N and write them down and take them with you along with a tape measure when you go to look at the 840 to be sure.
The "unbolted from the 8N, and bolted on to the 800 series with no welding, bending, etc." might be true if you have the proper mounting brackets for the 800 series, bit I don't think that's going to work with the 8N mounting brackets. If you have time and some fabrication skills you could probably modify the existing brackets or fabricate some new ones.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
