Company Logo Shop Now
TractorLinks.com
ford 2.3 gas 3 cyl.
rat0851
12-02-2019 19:53:02
I know nothing about the 2.3 gas 4 cyl. engine. could this motor be installed in my ford 4500 tractor to replace my ford 291 ci. 3 cyl diesel. Pros and cons to this motor. thanks
rat0851
12-03-2019 08:31:12
 Re: ford 2.3 gas 3 cyl. in reply to rat0851, 12-02-2019 19:53:02
Thank you Sean for your valuable knowledge. I think it is a car engine . I will pass on this engine. appreciate you help. Randal
Sean in PA
12-03-2019 04:03:27
Sounds like a car engine, so I don't think it would work without adding some sort of external framing. The engine on the Ford 3 cylinder tractors is a structural component, meaning that the engine block itself is part of the structural integrity of the tractor frame. It may not look like it on a 4500 because the backoe/loader subframe adds some strength, but what holds up the front of the tractor if the loader and backhoe were removed like on an ag tractor? The bolster (front axle support) is bolted directly to the engine, the engine is bolted directly to the transmission and the transmission is bolted directly to the rear axle. Most car engines these days are made to be as light as possible and probably wouldn't have enough strength support the weight of the rest of the tractor even if you could fabricate adapters that would let the engine bolt up to the bolster and transmission.
rat0851
12-02-2019 20:45:47
Thanks for reply.
Shaun Wallace
12-02-2019 20:31:24
Don't know about 2.3 4 cyl. The 4500 has 201 diesel or gas. It would take lots of adapting to fit. There is enough 201s in gas or diesel out there to replace what you have. There is even smaller cid 3 cyl out there that will work,just not as much power.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
