OregonAaron
Soooo, today I was using my ford 2000 and while I was moving some stuff around at my ranch it stuck in gear and it wont let me shift into any other gear. I was doing some very light duty work and only for about 15 min. The clutch works fine and it drives just fine in the gear its stuck in. No noises happened before it wouldn't shift and everything was as usual. The transmission is the 8 speed version. I did not have time today to take off the shifter housing and inspect it. What are some common problems that can cause this? I need to get this fixed asap since snow is coming and I need this tractor to work! Any suggestions would be appreciated!
