Ford 4000 weak high gears
8X2 transmission, slower than average take off. If you start
going up a hill, the tractor will slowly come to a stop.
Sometimes you can?t get in into gear when clutch is pushed in
either unless high/low shifter is in neutral. Clutch?
Id start by checking the clutch adjustment and free travel... Ive seen clutch discs glaze rather fast, if someone operating it uses the clutch pedal for a footrest. Check the oil level in the Trans too..
