I am installing a front mount Ford snow plow blade on my 1962 Ford 651. This plow is operated up and down with hydraulic pressure, with a front mount cylinder. I have a two way hydraulic valve under the driver seat. i am missing the front hydraulic cylinder. Does anyone have the specifications about the original cylinder like hydraulic rod diameter closed length and full open length.
Thank You
<a href="https://imgur.com/fbAQG2p">
fbAQG2pm.jpg" title="source: imgur.com"
</a>
Got a new cylinder for mine last year. Couldn't find the paperwork for it but can get you some info once it gets light out. I could not find a cylinder the same width as the original. The new one was a hair bigger so had to shave a bit off the inside of the collar that holds the piston. I bought the original cylinder to a hydraulic shop and they told me they didn't think that could get parts to repair it and it would be cheap to buy a new cylinder.
<a href="https://imgur.com/hItOTgS">
hItOTgSm.jpg" title="source: imgur.com"
</a>
Length of cylinder Closed center pin to center pin 19". Width is 2 1/2". If I remember correctly I think I got it from Northern tool but just google Nortrac cylinder and they will come up.
<a href="https://imgur.com/EagLZyp">
EagLZypm.jpg" title="source: imgur.com"
</a>
