Company Logo Shop Now
TractorLinks.com
Re: Bi-directional pistons??
welding man
11-11-2019 19:05:59
I don't want to wade in too deep over my head on this discussion but I think you are working on a BSD444HT engine. H for Headland and T for turbo. The tractor is Bi Directional, not the pistons. I have replaced the Headland pistons in the 3 cyl engines that were naturally aspirated and have never had a problem. The turbo piston may be different due to the size of the combustion chamber. The bore is 4.4 and the wristpin is 1.625 on both. The distance from the top of the wristpin to the top of the piston would need to be verified. I can get the rings for a good bit less than you were quoted but I have never personally seen a set of Headland pistons that were reusable. Pistons are still available but expensive.
Robert (ID)
11-11-2019 19:24:34
 Re: Bi-directional pistons?? in reply to welding man, 11-11-2019 19:05:59
yes the tractor is bi-directional.. the explanation Is the bi directional 9030 had over 17/1 compression ratio, the 7710 has a compression ratio of 15.6/1.. also the 9030 engine was rated at 2500 rpm a 7710 was rated at 2100.
Copyright © 1997-2020 Yesterday's Tractor Co.
