Company Logo Shop Now
TractorLinks.com
Order Ford 860 Parts Online
ford 860 not staying in 3rd gear
T L
11-11-2019 17:17:44
I purchased a 860 at auction and it won't stay in third gear unless you hold the shift lever. This tractor has inside wheel weights and outside pie weights and the tires are loaded. I think this tractor was used for plowing in third gear and probably has worn gears. The shift lever feels like the de tent spring and ball have the same pressure in each gear. What should I look for when I take this apart and where can these parts be purchased?
pomester
11-18-2019 18:32:02
 Re: ford 860 not staying in 3rd gear in reply to T L, 11-11-2019 17:17:44
this is 4th gear in a 961, but the mechanism is similar across all the gears -
in this case, I was unable to shift into 4th - the sliding coupler did not fully engage the teeth and finally worked no more - I replaced the whole shaft assembly, which cured the issue - I did not really analyze what happened to the original - I found evidence someone had been in there before and cobbled things - I replaced the shift detent shaft also, as it had been ground on -
T L
11-21-2019 20:24:21
 Re: ford 860 not staying in 3rd gear in reply to pomester, 11-18-2019 18:32:02
Thanks for the pictures. My third gear looked about the same so I ordered a new gear from this site. I have pulled the transmission out and took everything apart. It wasn't hard but took a lot of time. Thanks for every ones help.
Bern
11-12-2019 12:48:39
One or two things are going on here in my mind. Either the shaft where 3rd gear resides has too much end play of all the components, and/or the clutching teeth on the 3rd gear plus the mating coupling have excessive wear. Both will require a split and teardown.
If the clutching teeth are worn, that is caused by operator abuse, and not hard pulling.
5azzmonkey
11-12-2019 06:44:34
Couldn't agree more .....
-Dave
Sean in PA
11-12-2019 06:14:06
Even though the detente's all "feel" the same, I would pull them first before tearing into the transmission, as that is the most likely culprit, and they can be easily accessed without tearing anything else apart. The detente's are accessed by the 3 slotted screw heads on the left side, just in front of the radius rod mounting pad. There is an o-ring, a spring and the actual detente plunger under each screw head. If the plunger doesn't cone out easily, use a small magnet.
T L
11-12-2019 12:23:49
 Re: ford 860 not staying in 3rd gear in reply to Sean in PA, 11-12-2019 06:14:06
I pulled the detente spring and seat out and they looked fine but I still pulled another one out and switched them around trying to see if that would help but no luck. I also looked at the shift lever where the seat contacts the lever and it looks fine so I guess I will have to go into the tranny. Thanks for the advice but I usually don't get lucky.
T L
11-12-2019 07:37:55
Thanks, I will give that a try.
Threewilsons
11-11-2019 20:29:49
You can still buy a new 3rd gear for your 5 speed. This site sells it for around $165. To verify you need this new gear you ll want to remove the top of the transmission, drain the tranny oil and get a diagram, a flashlight, and maybe a mirror. You may want to put the shifter back on and watch the action as you shift in and out of third gear. The wear on 3rd gear will be exposed as you shift the collar across to Reverse. The shift collar might be worn but I don t think it s available. Even so, a new third gear will last a long time.
I believe that the replacement can be done by only splitting behind the tranny. I replaced mine with trans completely removed. Get the right book and follow it; there aren t any shortcuts. No special tools are required but there s nothing easy about this job. Take good pics of the internal shift rods before you disassemble it; the book isn t too clear.
Good luck,
Joel
T L
11-18-2019 18:09:51
 Re: ford 860 not staying in 3rd gear in reply to Threewilsons, 11-11-2019 20:29:49
It finally warmed up a little here in NY and I pulled the top cover off the transmission and put the shifter back on. Everything looks good. What should I look for? The gears look fine. Someone also said there could be too much play somewhere.
T L
11-12-2019 05:09:47
Joel thanks for the advice. I will get a book to help me. I have repaired several manual truck and car transmissions over the years but never did internal work on a tractor transmission.
WayneIA
11-11-2019 18:38:10
Since you can not get new parts and used parts are hard to come by I have reduced the end play between the drive hub and the problem gear by putting in a different thrust washer replacing the regular hard thrust washer, Since you won't be farming the whole county with this tractor a simple thrust washer of the right demention will work. leave just a tiny bit of end play for oil. Hopefully there is enough left of the connecter teeth to drive it.
T L
11-11-2019 19:20:35
 Re: ford 860 not staying in 3rd gear in reply to WayneIA, 11-11-2019 18:38:10
How do I know where to add this thrust washer?
Robert (ID)
11-11-2019 17:22:51
That is a common complaint with the 5 spd transmissions. Do a search there are other posts with the same symptoms.
T L
11-11-2019 17:58:39
 Re: ford 860 not staying in 3rd gear in reply to Robert (ID), 11-11-2019 17:22:51
I am new to this. How do I do a search?
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
