Want to overhaul vane pump and have been following FO-19 manual. Fig FO87 shows exploded view of pump. I can?t get pump body (31 in fig fo87) and mounting housing (5) to split apart. The cap screws/bolts are all removed. All the components between the body and housing ( pump shaft, bearings, etc.) are still together and inside the housing and pump body.
What would hold this together how does this section come apart?
Winter project and not able to switch to piston pump at this time. Thank you in advance for your help.
