Help with lift control mechanism .. 67 Ford 3000
greymond
I am doing some trenching with a modification I welded up for my blade. I am trying to get the level even on the scraper. I cant seem to get the control arm to work.. photo below. Any ideas on how that things works?
thanks
It is probably froze up from sitting just below your circle where it is threaded onto the lower lift link. Good soaking of solvent and diesel will help. Pull that zerk out on the lower link and try to dig out the crud and soak it as well. May need some mild heat to get it loose. You will want to take the whole lower unit apart and clean out all the threads. Won't hurt to soak the upper unit by the crank, the gears and let it soak down into the shaft.
(quoted from post at 19:36:51 11/10/19) I am doing some trenching with a modification I welded up for my blade. I am trying to get the level even on the scraper. I cant seem to get the control arm to work.. photo below. Any ideas on how that things works?
thanks
Your handle as been bent, should like like the one on my 801.
It's just a simple hand crank, most likely the threaded rod is rusted and froze in the lower link.
