Company Logo Shop Now
TractorLinks.com
Order Ford NAA Parts Online
Re: NAA quits running after 5 minutes
Jim L WA
11-10-2019 09:42:04
You need to do two tests. First, pull the plug at the bottom of the carbruater and see if it will fill a pint jar in 2 or 3 minutes. If so then you don't have a fuel flow problem. Second, when the tractor starts acting up, and quits, immediately pull the coil wire from the distributor cap and hold it a good 1/4 inch from a clean spot on the block and with the key still on crank the engine. You need so see if you are getting a good strong spark out of the coil. My guess is that you will not. But do these tests first, don't go out and start throwing parts at it. That can get expensive. If you do get a good fuel flow and a good spark let us know and we can go from there. By the way, you never said if this is an OEM 6 volt system, or a 12 volt conversion.
Copyright © 1997-2020 Yesterday's Tractor Co.
